Tim Cheal Posted August 4, 2013 Share Posted August 4, 2013 Can anybody help me with this rather odd problem. I am setting up a Seagull Grob Tutor, which needs micro servos on the ailerons. I have purchased 2 HS 85 MGs for the ailerons. If I connect one HS85MG to my Spektrum AR8000 receiver all works well, but if I connect 2 both stop working - erratic responses and apparent interference between the 2. The same happens to any combination of servos on the AR8200, three servos (HS 311s for what its worth) work fine in any combination, but as soon as I plug in either HS 85 MG the system becomes erratic and doesn't work. I tried a Tower micro servo and that worked fine. If I plug one or both of the HS 85 MGs into an AR6210 no problem. I note when they bind the AR8200 uses 11msec, the AR6210 uses 22 msec. Is this a compatibility issue? Does anyone have any ideas if I can fix this, or what micro servos I should replace them with that are strong enough and that will work?? Many thanks in anticipation. Tim Quote Link to comment Share on other sites More sharing options...
Ben B Posted August 4, 2013 Share Posted August 4, 2013 Can you not set the receiver to 22ms via the tx?????? I suspect that would sort it. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted August 4, 2013 Share Posted August 4, 2013 You don't mention the Tx, but if it shows the frame rate you should be able to change it - you can on my DX8. Set it to 22ms and all should be well. The Tx sets different frame rates depending on the receiver, which is probably why your other Rx is OK. Quote Link to comment Share on other sites More sharing options...
Tim Cheal Posted August 4, 2013 Author Share Posted August 4, 2013 It's a DX8 so that is very useful. Thank you. I have seemingly changed the frame rate to 22msec, but that does not solve the problem. But, if I select 22ms from the frame rate menu (and as it happens I can select DSMX or DSM2 as well) it binds at 2048/11 msec DSM2 to the AR8000 whatever.Thus the setting of the frame rate doesn't seem to make any difference. I have followed the manual, but perhaps there is more to it! Tim Quote Link to comment Share on other sites More sharing options...
001 Posted August 5, 2013 Share Posted August 5, 2013 If you are just setting up the model could you try moving the transmitter further away from the receiver? I notice that this does make a difference when trying to bind. (Just a thought!) Quote Link to comment Share on other sites More sharing options...
Tim Cheal Posted August 5, 2013 Author Share Posted August 5, 2013 Thanks, but still nto sorted! I dont think its the binding though, its the HS 85 compatibility! I will try some HS 82s and see how they work. Tim Quote Link to comment Share on other sites More sharing options...
Tim Cheal Posted August 5, 2013 Author Share Posted August 5, 2013 OK Everyone can relax. Looks like problem solved by a new battery! I thought the 4.8v cell I was using was working well, but I have just connected the 6.0v cell that I have charged up and all works fine. Strange that all worked with the AR6210, leading me to false conclusions. Oh well, don't tell the missus about the 2 X HS 82 MGs I ordered!! Tim Quote Link to comment Share on other sites More sharing options...
Glyn R Posted August 5, 2013 Share Posted August 5, 2013 I have had this problem with some servo Rx combinations. Quote Link to comment Share on other sites More sharing options...
