andyh Posted September 25, 2013 Share Posted September 25, 2013 I have a wot-4 foam-e & am musing over a good prop choice ... I'm after good static/low-speed thrust & quick acceleration, plus some decent prop braking power-off I believe the model comes with an 11x8 as standard, & this provided a decent amount of oomph & vertical performance (before I broke it). I replaced it with an APC 11x7 & now it has noticably less vertical performance & static thrust, although the acceleration is still pretty immediate I appreciate that on electric the motor will be pulling less power due to the lower prop-loading, vs. IC where you might get better performance with the same prop change as it would allow the engine to rev higher so, I was thinking, 12x7? 13x6? bigger prop moving more air, although less fast = similar/better static/low-speed thus & more prop-braking power-off? I'm not interested in speed, quite the reverse any thought welcomed Andy Edited By andyh on 25/09/2013 20:11:18 Quote Link to comment Share on other sites More sharing options...
andyh Posted September 25, 2013 Author Share Posted September 25, 2013 thrust* Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted September 26, 2013 Share Posted September 26, 2013 Do make sure you check the WOT current with a wattmeter won't you Andy....that will tell you if you have under (or more importantly) overloaded the motor/ESC.. Quote Link to comment Share on other sites More sharing options...
andyh Posted September 26, 2013 Author Share Posted September 26, 2013 wattmeter & tacho on order at the moment Quote Link to comment Share on other sites More sharing options...
crispin church Posted September 27, 2013 Share Posted September 27, 2013 on watt meter when you get it and put a pull scales with strap tail connected to wall to see how much pull you get try 11x 6 and below and go up to 12x5 12x4 don't think your be able to go 13x4 right it all down and keep it for future Reffence for less speed go down in pitch up in length and don't forget to make sure you got ground clearance Quote Link to comment Share on other sites More sharing options...
