Barrie Dav 2 Posted January 29, 2014 Author Share Posted January 29, 2014 Many thanks for that Andrew. Really useful. That finished one is superb. I'll register on the forum. Quote Link to comment Share on other sites More sharing options...
KingKade Posted February 1, 2014 Share Posted February 1, 2014 Posted by John Milne on 16/01/2014 20:33:52: I've always used the Tamiya acrylic thinners but I don't see why water can't be used, try it. For the varnish use Pledge Multi Surface Wax , it used to be sold as Johnsons Klear, (I get mine from Sainsburys), one bottle will last forever. It sounds wrong but it is a fantastic product for us modellers. spray or paint over the paint finish, then add decals and spray or paint over the decals again, it is also a fantastic base for adding various weathering processes. I also use it to give canopies a cystal clear look. For those of us with foam models it makes a fantastic sealing coat to protect decals and stops the foam getting grubby, it can painted on with a brush or sprayed and dries leaving a tough durable clear satin finish that weighs next to nothing and is very cheap.. Regards John I have a foam model and would like to protect the foam and seal the decals... What should i do just spray it over everything? A light mist? Kk Quote Link to comment Share on other sites More sharing options...
ernie carter Posted November 20, 2016 Share Posted November 20, 2016 building a display model of TSR2 approx 18" long, depron foam covered. What area would a 10ml jar of tamiya paint cover using a voila airbrush. My first attempt with airbrush!"!!! Quote Link to comment Share on other sites More sharing options...
