david chapman 4 Posted April 18, 2014 Share Posted April 18, 2014 do i need a battery for my plane if i am running a irvine 46 engine Quote Link to comment Share on other sites More sharing options...
Chris Anthony Posted April 18, 2014 Share Posted April 18, 2014 Yes, to power your radio gear (receiver, and servos via the receiver). Quote Link to comment Share on other sites More sharing options...
david chapman 4 Posted April 18, 2014 Author Share Posted April 18, 2014 what type, the engine is 46 irvine,4 standered servos,futaba 6excontrol box and the plane is tutor 40 mk2 Edited By david chapman 4 on 18/04/2014 16:09:41 Quote Link to comment Share on other sites More sharing options...
Andrew767 Posted April 18, 2014 Share Posted April 18, 2014 Hi David You need a 4 cell 4.8v Rx pack......Have a look at Airtek, Hobbyking etc. or your local model shop. Usually around a fiver. Andrew Quote Link to comment Share on other sites More sharing options...
david chapman 4 Posted April 18, 2014 Author Share Posted April 18, 2014 tjd models have a lot to choose from but the question which one Quote Link to comment Share on other sites More sharing options...
flight1 Posted April 18, 2014 Share Posted April 18, 2014 Look for the Rx battery selection ( NiMh ) and then any pack 4.8v pack greater than 2000mAh just choose the best shape square or flat to suit best fitment into the model you got. and don't forget a suitable smart charger. Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted April 18, 2014 Share Posted April 18, 2014 I would actually recommend a 5 cell NiMH (i.e. a nominal 6 volt pack) as this will give you a comfortable margin in voltage before the dreaded brown out voltage is reached. That David is the voltage at which the Rx ceases to function due to a, usually momentary, voltage drop caused by multiple servo movement. Quote Link to comment Share on other sites More sharing options...
Andrew767 Posted April 18, 2014 Share Posted April 18, 2014 Hi David Peter makes a very good point there. As for which one?..Sanyo enerloops are very good, if a little dearer. Andrew Quote Link to comment Share on other sites More sharing options...
