Battery for Tutor 40 mk2 ?
david chapman 4
I would actually recommend a 5 cell NiMH (i.e. a nominal 6 volt pack) as this will give you a comfortable margin in voltage before the dreaded brown out voltage is reached. That David is the voltage at which the Rx ceases to function due to a, usually momentary, voltage drop caused by multiple servo movement.
