Iain Hale Posted November 8, 2014 Share Posted November 8, 2014 I wish to switch between motor control and progressive crow breaking. By assigning the throttle stick using the 3 position switch (B) . So one way gives throttle in the conventional way, and switching the other way you have no motor but progressive core breaking. Any help much appreciated! Quote Link to comment Share on other sites More sharing options...
Pete B Posted November 9, 2014 Share Posted November 9, 2014 It's a matter of selecting a number of Flight Modes, then setting up the model for each individual mode, based on the switch B position. I think this post from aerocal over on the RCGroups DX8 Sailplane thread will give you an idea: If I understand right you want your Flightmodes controlled by the Flap switch? You want Motor enabled only during Launch mode? The rest I kind of grasp. First you need to start over. Reset the model. Do the name and Wingtype selection. Set motor to spoiler and click again. you will get to Active Positions screen.Make Pos 0 black. Thr/Spoiler stick will only control motor in that mode. In FMode Setup set your modeswitch to Flap. Set your Flap and Ail travels in Camber Preset and Camber System menus based on your Flightmodes. Pete Quote Link to comment Share on other sites More sharing options...
