Snorbitz Posted February 26, 2015 Share Posted February 26, 2015 Just a quick question. Can a 2.4ghz module be fitted to a JR X378. 35MHZ set?. Quote Link to comment Share on other sites More sharing options...
Fatscoleymo Posted February 26, 2015 Share Posted February 26, 2015 If it has the plug in module in the back , yes. I did this with my x388 with a Frsky module - about £20. Worked just fine. If it does not have the plug in module you can still fit an internal 2.4 module - easy to do and with a switch fitted you can swap between 2.4 and 35meg very easily. Fats Quote Link to comment Share on other sites More sharing options...
gangster Posted February 26, 2015 Share Posted February 26, 2015 The frsky "hack module" will fit in nicely. I actually removed the 35 module and strapped the frsky module to a plate that bolted in its place seemed so much more solid than having the module "floating round the case. Good modification IMHO Quote Link to comment Share on other sites More sharing options...
