Craig Spence Posted November 11, 2015 Share Posted November 11, 2015 Hi all, I haven't posted on here for some time, I'm coming back into flying after a 3 year break and im shocked at the vast changes if im honest. So to the topic, I will be treating myself in January to a pilot rc Sbach 342 30cc. I have loads of questions and need help if you could. 1; The model weighs 4.85kg (as it comes). It requires x6 servos, what torque should I be looking at on them?, also does the throttle servo need to be of high quality?. 2; I am looking at LiFe battery's for the receiver, what mah will I require 3000+? 3; what battery should I have for the engine?, DLE 30cc. 4; Is a battery backer the way forward or dual batteries with dual harnesses suffice?. 5; Can you get 20x4wide wooden props? and would this be ok for DLE 30cc. Prop range (18x8, 18x10, 19x8 & 20x8. 6; I take that I will need a kill switch?. Any help would be greatly appreciated. Cheers, Craig. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted November 12, 2015 Share Posted November 12, 2015 Craig you seem to have duplicated this thread see here....as the other thread is up & running I've locked this one to prevent any confusion.... Quote Link to comment Share on other sites More sharing options...
