Silver Wolf Posted November 28, 2015 Share Posted November 28, 2015 I will be looking to replace my old desktop with a laptop in the near future. I would like to be able to run the profly 7 RC flight sim and start to use turbo CAD. Would be grateful if any one has experience or comments on what might be suitable. Regards SW Quote Link to comment Share on other sites More sharing options...
Trevor Rushton Posted November 28, 2015 Share Posted November 28, 2015 Sw I cannot tell you what to go for but I can share my experience. I run Turbocad ; I bought it last year to replace my old and unsupported Autocad lt. I wanted to learn 3D cad. I have a 15 inch Acer Laptop (aspire e1 4gb ddr3 memory and pentimento 2117u 1.8ghz and 2mb cache. I do not run a flight sim on it. Performance has been less than sparkling; Turbocad takes an age to load and does not always seem to perform as expected; it's okay but only just okay. My version uses a lot of space on the screen for icons so with 15.6" you are forever having to scroll around the screen. I got a bit frustrated with the experience and have been thinking about something with a bigger screen and better memory/ graphics. So, my suggestion is go for the biggest screen you can get, make sure it's got a good graphics card and plenty of memory/processing capability. I am sure that there will be others who can give you a far more technical reply but my experience would be to avoid the lower cost machines which are not really designed for graphics. Good luck! I might also benefit from your enquiries! Quote Link to comment Share on other sites More sharing options...
flight1 Posted November 28, 2015 Share Posted November 28, 2015 Well turbo cad needs a better spec pc than your flight sim so spec for turbo cad and it will be good enough for the flight sim. Ram at min 4gb but 8Gb or more is better 64bit operating system as its spected for that intel i5 or i7 cpu , nothing wrong with a standart hdd but a SSd will be faster and large back ups can be on a portable HDD. A large screen but if you have HDMI you can get a nice 24 0r 26 inch monitor in which case you can dual screen. Also in the latest versions there is Redsdk which speeds things up a lot so you need to double check the gpu (graphics card)supports it. a list here all in all go for the best thats in your bugget Edited By flight1 on 28/11/2015 11:14:52 Quote Link to comment Share on other sites More sharing options...
Silver Wolf Posted November 28, 2015 Author Share Posted November 28, 2015 Had thought about an apple but cost + small screen seems to rule it out. I am considering the Dell Inspiron 17 5000 series with intel 7 and 8GM memory. SW Quote Link to comment Share on other sites More sharing options...
flight1 Posted November 28, 2015 Share Posted November 28, 2015 looks good the dell with 17 inch touch screen (do you need that touch capability) but check the gpu is good enough for your purpose Quote Link to comment Share on other sites More sharing options...
Silver Wolf Posted November 28, 2015 Author Share Posted November 28, 2015 Not sure if this model is touch screen but the Graphics card is a AMD Radeon™ R5 M335 4GB D Quote Link to comment Share on other sites More sharing options...
