Steve Hargreaves - Moderator Posted February 29, 2016 Share Posted February 29, 2016 Excellent news Tom.....glad we could help..... Quote Link to comment Share on other sites More sharing options...
Paul C. Posted February 29, 2016 Share Posted February 29, 2016 Hi tom, I have an acro wot foam and it is a great flyer and goes together easily. Things I found was that when attaching the tail check that any excess glue is removed with modeling knife, I did not spot this on mine so the tail plane did not sit square easy fix no problem. Found that the battery leads when connected to the esc are very close to the rotating motor can and could rub through. Make sure you push them down the side of the motor mount into the hollow side check this will give you clearance. I ended up adding a small amount of lead to the tail to get the c of g bang on, found this helped when fling inverted. Hope this helps ☺👍 Paul. Quote Link to comment Share on other sites More sharing options...
Steve Perry 1 Posted February 29, 2016 Share Posted February 29, 2016 Great Explanation for Methanol I never knew that!!!!! Every day is a School Day. Thanks for posting.. Quote Link to comment Share on other sites More sharing options...
