fly-navy Posted July 15, 2008 Share Posted July 15, 2008 SWMBO purchased a combi belt and disc sander for my birthday from Axminster tools,nice bit of kit.Where do you guys get your discs from(125mm dia) 300-400 grit sticky back self adhesive?I ordered some discs from them but when I took the original one off and tried one of the fine grades it wasn't sticking very well,so removed it and cleaned backing disc with meths and waited for it to evaporate next disc stuck a bit better but I am a bit wary of it flying off(yes I wear safety specs) they do not seem to be very sticky and I am sure I have seen a friends that was a bu**er to remove from your hand if the disc stuck to it.Cheers John Quote Link to comment Share on other sites More sharing options...
winchweight Posted July 15, 2008 Share Posted July 15, 2008 Try Netto, they do a similar sander and it uses self adhesive discs. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 15, 2008 Share Posted July 15, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
birdy Posted July 15, 2008 Share Posted July 15, 2008 Ahhh screwfix... What a wondifle shop! Quote Link to comment Share on other sites More sharing options...
fly-navy Posted July 15, 2008 Author Share Posted July 15, 2008 Cheers Winch.er Shaun,will have a look in Kidderminster tomorrow when we are shopping,thanks eric & Birdy will also look in Screwfix as I believe a new one has opened up in town.Cheers John Quote Link to comment Share on other sites More sharing options...
Allan Jordan Posted July 17, 2008 Share Posted July 17, 2008 Hi Sailor (was going to type "hallo sailor " then I thought better of it !! The better alternative would be to convert the disc to the "velcro " type. I bought my kit from " Machine Mart " If memory serves it cost about £4. 00. including the post and packing. I highly reccomend the kit as it is very easy to change from coarse to fine grit. Try this www.machinemart.co.uk Quote Link to comment Share on other sites More sharing options...
fly-navy Posted July 25, 2008 Author Share Posted July 25, 2008 Hi Allan,now you know why I changed name to fly-navy from sailor,every e.mail from mods started "Hello Sailor",thanks for info I was going this way and still may do,I got in touch with Axminster and they supplied some more discs FOC without any prompting suggesting that my order might have been old stock and lost some of the stickiness these new ones certainly seem better got to get it sorted ready for the Hurricane planJohn Quote Link to comment Share on other sites More sharing options...
Allan Jordan Posted July 30, 2008 Share Posted July 30, 2008 Hi fly navy, if you do decide to go "velcro " I can assure you that you will be pleased with the end result, I changed to this type about fours ago because I got fed up with trying to remove worn out discs, they are very easy to change if you need to change from one grit to another. I wouldn't use any other kind now.Regards Allan Quote Link to comment Share on other sites More sharing options...
Declan Barry Posted July 30, 2008 Share Posted July 30, 2008 Hi Allan..Can you remember the order code from Machinemart. I'm looking to do something similar with my sander.Declan Quote Link to comment Share on other sites More sharing options...
