Allan Bennett Posted December 11, 2016 Share Posted December 11, 2016 The default countdown timer in my Taranis says "eight point zero", "seven point zero" etc., then simply "one" when it gets to one minute, followed by "thirty seconds" and so on. I noted that another flyer's Taranis was saying "eight minutes" etc. He told me to download the latest voice file. TX Companion says my software is up to date (2.1.9). When I go to File > Downloads I get the options to Download FW or to Download Voice, but then I get a list of five .zip files and one .csv file, most of which are dated 14-Apri-2016. The files in the english-american-taranis.zip collection available for download were all modified on 11-Nov-15 9:54 PM despite the later date on their .zip file. I've copied them into my TX Companion SOUNDS folder, but the time still says "eight point zero" etc. How do I get it to say "eight minutes" please? Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted December 12, 2016 Share Posted December 12, 2016 If you have a Taranis plus **LINK** If you have the original version **LINK** Make sure you also replace the 'SYSTEM' folder that is where all of the standard sounds are for the timer etc. Personally I use the 'Amber' sounds because the voice is nicer Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 12, 2016 Author Share Posted December 12, 2016 Thank you WolstonFlyer. I have a Plus, and the files in your first link are the ones I used. On closer inspection though, I see that the SYSTEM folder had placed itself inside the existing SYSTEM folder, instead of replacing it and its contents. Correcting that has got me the correct phrases. I'm using the Amy voice from TTSAutomate for custom phrases for all of my switch positions. Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted December 12, 2016 Share Posted December 12, 2016 I am glad you got it working Allan TTSAutomate does look interesting, I will give that a go thanks! Quote Link to comment Share on other sites More sharing options...
