Daniel Attree Posted October 25, 2017 Share Posted October 25, 2017 Hi All, please can any of you tell me the make and manufacturer of this glider, it was a gift but has no instruction, i am a mech engineer but if i can id the model i may find some PDF instructions which would be helpful Thanks Danny www.modelmasteruk.com Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted October 25, 2017 Share Posted October 25, 2017 Looks like the JP Greensleeves/Maxford USA Greensleeves or BMI Valbella but they are electric and this glider looks like it has a T tail. Looks Chinese, possibly made in the same factory. Cheers Gary Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted October 25, 2017 Author Share Posted October 25, 2017 Thanks Gary, it is all electric but no motor in the nose, just a pure glider. Danny Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted October 25, 2017 Share Posted October 25, 2017 No worries, I meant electric motor launch by electric. There is another BMI glider with a T tail, Cortina 2200 but that is also electric launch and looks like it doesn't have ailerons. It might forever remain a mystery! Quote Link to comment Share on other sites More sharing options...
Martyn K Posted October 25, 2017 Share Posted October 25, 2017 That looks lovely. Where do people find these things? It shouldn't be too difficult to work out where everything goes if you cant find instructions. Post a build blog for us to follow please Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 25, 2017 Share Posted October 25, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted October 25, 2017 Author Share Posted October 25, 2017 it is a plastic fuselage with 3 servos, 2 for wings and one for the horizontal stab/Aileron, on the underside of the Aileron there is a small bracket yet to be positioned, control cable runs the length of the fuselage exiting the top of the T Tail under the Aileron. Thanks Danny www.modelmasteruk.com Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted October 25, 2017 Author Share Posted October 25, 2017 Yep that is my bad i really should know better considering the amount of plane models i have built, dowttt!!!! Trying to do about ten things at the same time. Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted October 25, 2017 Author Share Posted October 25, 2017 Some more images More images. Edited By Daniel Attree on 25/10/2017 18:35:55 Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted October 25, 2017 Author Share Posted October 25, 2017 All new to me, it was a gift, I believe its about 9 years old Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted October 25, 2017 Share Posted October 25, 2017 Not sure but it seems to me that there is a third wing panel missing, a centre section. The span is not enough for a thermal type model. Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted October 25, 2017 Author Share Posted October 25, 2017 Wings join together with a carbon rod.Dan Quote Link to comment Share on other sites More sharing options...
Martin Whybrow Posted October 25, 2017 Share Posted October 25, 2017 The wings look very much like the Greensleve wings; the Greensleeve has a conventional (low horizontal stabiliser) tailplane; the wingspan is 2m and is electric powered with a motor in the nose. The wings are 2 pieces, joined with a steel bar; the wings mount via 2 dowels at the front and 2 M6 nylon bolts at the rear. The Cortina has the same fuselage, but has an all moving T tail, 3 part wings with no aeilerons and a span of 2.2m. I have both plus two more unidentified models with the same fuselage! I also have the instructions for the Greensleve. Edited By Martin Whybrow on 25/10/2017 21:01:21 Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted October 25, 2017 Author Share Posted October 25, 2017 It's most definitely a T tail, any instructions you have would 've good as there is bound to be great commonality of parts, main wing is two piece and looks to secure the same, definitely two small bolts and joining rod.Can you copy any instructions and email me? Quote Link to comment Share on other sites More sharing options...
Martin Whybrow Posted October 25, 2017 Share Posted October 25, 2017 Send me a message with your email address and I'll send it to you. Quote Link to comment Share on other sites More sharing options...
Daniel Attree Posted November 1, 2017 Author Share Posted November 1, 2017 Hi Guys, i have managed to get it all assembled and function tested but i have a question, i initially had each wingtip aileron moving the opposite direction as i supposed this is how the the glider would turn in flight, ie when control flicked left one aileron goes up and the other goes down, is this correct?? The is no rudder on the vertical tail just the normal t tail with one long flap. Should the wing ailerons move up and down in unison or independently as i have them now? Thanks Danny Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 1, 2017 Share Posted November 1, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
