Rob2018 Posted August 5, 2018 Share Posted August 5, 2018 Is it possible to have spoilerons when using a V-Tail? Trying to set up a E-glider with 2 servo aileron wing and 2 servo V-tail (Ele/rudd) Failing miserably to get the Flap menu out of 'inhibit'. In the Switch setting menu I have everything set to 'Inh' apart from 'Flap' which is allocated to the Gear switch. I have a similar setup on a T-tail glider and the spoilerons work fine. Don't know if I'm overlooking something obvious or its just flaps won't work with a V-Tail. Quote Link to comment Share on other sites More sharing options...
