FilmBuff Posted June 20, 2019 Share Posted June 20, 2019 Being increasingly drawn to these range of gliders. Art Hobby Gliders Wondering of level of work is still to be done? I've seen old videos and build logs of people having to cut out cockpit apertures, cut foam away from the root for joiners, and sanding root and tip panels for dihedral etc. I think control surfaces are already hinged. None of this bothers me - just curious! Edited By FilmBuff on 20/06/2019 17:16:53 Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 20, 2019 Share Posted June 20, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
FilmBuff Posted June 20, 2019 Author Share Posted June 20, 2019 Posted by Andrew Ray on 20/06/2019 17:28:55: I have the 2.5m Orion EV. Lovely kit and flies very well, I fitted a Hacker geared motor driving a 16" prop powered by a 3s 2200, it will climb vertically with ease and is capable of covering the sky quickly. Thanks Andrew. Re the blocks in the wings for the fuselage fixing. Does that mean you then have to drill them? Don't fancy that without a pillar drill... Re your wing finish. How durable and water resistant was applying lacquer direct to the veneer? I was toying with light weight glass cloth or film. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
Graham R Posted June 20, 2019 Share Posted June 20, 2019 I am just putting together their Silent Pro 3.4. Its very straight forward, good instructions and very good quality well finished components. Very happy Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 21, 2019 Share Posted June 21, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
