richard crosby 2 Posted September 20, 2008 Share Posted September 20, 2008 Hi - Need some advice please - I just ordered a new brushless setup for my Kyosho Stratus 2000s. this one- its meant I think for the the multiplex easyglider. Do you think I've gone for too much power? The Stratis is a bit heavier.Am I going to get into problems?! I guess I'll need some ballast to keep the c of g in place. Anyone had any experience of this in the stratus?CheersRich Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 21, 2008 Share Posted September 21, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
richard crosby 2 Posted September 21, 2008 Author Share Posted September 21, 2008 Eric - Thats reassurung - thanks.I estimate I may have around 100w / lb available so launching should be fun but as you say some restraint may be in order. Seems to be little discussion about the Stratus - possibly it was eclipsed by the EasyGlider, but as a beginner I didn't really want ailerons. Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 24, 2008 Share Posted September 24, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
richard crosby 2 Posted October 12, 2008 Author Share Posted October 12, 2008 Well - I finally got the set up installed working and in the air this weekend. - so I now know the new set up gives me a better than 1:1 power/weight ratio. I had several frightening initial flights but I now realise this was due to too much power for me to handle on takeoff. The glider tended to go vertical and roll ( maybe a bit of torque effect?) causing me to over react and get in a muddle. It looked like it was stalling. Later launches on about 60% power were much more controlled. I think the near vertical climb was keeping airspeed low and hence reduce control?I discovered later that aftr takeoff, setting a moderate 40% ish throttle then trimming elevator to suit , gave me a nice easy peasy flight. I guess this is what you experienced electric glider pilots do all the time?I'll keep all that extra power in reserve for when I can handle it I think. I think 100% power might need some stick forward to keep the aircraft under full control.anyhow thanks to all on the forum for advice . I think I have finally cracked it!!! Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 12, 2008 Share Posted October 12, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
richard crosby 2 Posted October 14, 2008 Author Share Posted October 14, 2008 good idea - how much 'down thrust angle' do people go for with this type of glider? Quote Link to comment Share on other sites More sharing options...
