jonathan broadhurst Posted September 27, 2008 Share Posted September 27, 2008 I've started glueing my Goldgerg Gentle Lady. I have built stab,fin and rudder. The plan says that i can hinge the rudder and elevator using two methods. Centre bevel technique or hinged covering.Can anyone advise me as to which is best method (bearing in mind i'm a new builder). Thanks Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 27, 2008 Share Posted September 27, 2008 For ease, probably the centre line using mylar / pinned hinge is best. Hinge covering systems do tend to provide a better control surface due to no air gap, and look neater if done well - but on a gentle lady - your unlikely to notice. Quote Link to comment Share on other sites More sharing options...
jonathan broadhurst Posted September 27, 2008 Author Share Posted September 27, 2008 Thanks for that Timbo. Not done any covering before so i was edging towards a centre bevel hinge. Quote Link to comment Share on other sites More sharing options...
birdy Posted September 27, 2008 Share Posted September 27, 2008 Sorry to but in, but how do you do the hinges. I have some weird polpropoprolene (or something like that) hinges, which have hard tabs and a thin plastic central bit. How do you go about putting those in? Thanks,Birdy Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 27, 2008 Share Posted September 27, 2008 same as regular mylar hinges really. Fit dry, then very carefully and sparsely drop a little thin cyano into the slot where they fit. I also always pin all my hinges. I drill a 1 mm hole throught the trailing edge / surface straight through the hinge and out 'tother side. Then I insert a single drop of thin cyano and quickly push home a cocktail stick, cut off flush with sharp scalpel and then hide the job with a tab of covering film / paint . Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 27, 2008 Share Posted September 27, 2008 does this help? Quote Link to comment Share on other sites More sharing options...
birdy Posted September 28, 2008 Share Posted September 28, 2008 Yes. Thanks! Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted September 28, 2008 Share Posted September 28, 2008 Another but in aswell, sorry Im making a Fling wing and a 36" tiger moth atm and I want to know are there any 'home made' hinges I can make for these 2 models? I thought of Camera film, is that any good?Thanks, Ben. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 28, 2008 Share Posted September 28, 2008 I successfully use cut up floppy disks on smaller models. Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 28, 2008 Share Posted September 28, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted September 29, 2008 Share Posted September 29, 2008 Great! Thanks guys Quote Link to comment Share on other sites More sharing options...
