Steve Newton Posted October 13, 2008 Share Posted October 13, 2008 Hi What are my options in covering an under camber wing, i would like to use solartex but i am not sure if this will hold and want to bottom out.Thanks Steve Quote Link to comment Share on other sites More sharing options...
Bert Posted October 13, 2008 Share Posted October 13, 2008 SteveMy experience is that it is best if you have cap strips and paint them with balsaloc or something similar before covering. Although it will work without strips if you are careful not to shrink it too much. After running the sealing iron over the rib rub it down with a soft rag (as recommended, in the instructions I think). When shrinking it, try not to let the sealing tool touch the actual ribs so as not to soften the adhesive.The same applies to Solarfilm. HTH Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 13, 2008 Share Posted October 13, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
