Justin Needham Posted October 13, 2008 Share Posted October 13, 2008 Hi. I have some old Ripmax SP resin and hardener. It is still OK enough for a gash job I have in mind, but I don't know the proper ratio. I've scoured the web but can't find the info. The quantities in the two pots don't give much away, it could be probably in 3:1 or 4:1. Does anyone still have instructions? Thanks Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 13, 2008 Share Posted October 13, 2008 2 cm "worm" of hardener to 100ml of resin ... I think Quote Link to comment Share on other sites More sharing options...
Justin Needham Posted October 13, 2008 Author Share Posted October 13, 2008 Thanks Timbo, but it's a two liquid set. Containers originally 392 gm and 108gm. I'm not sure the proper ratio would really be 3.62:1. Sounds unlikely. Perhaps this is a 3:1 by weight mix, I don't know. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 14, 2008 Share Posted October 14, 2008 ah sorry...wrong one then Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted October 14, 2008 Share Posted October 14, 2008 I have some and on the box it says 3 parts resin to 1 part hardener. Quote Link to comment Share on other sites More sharing options...
Andy Butler Posted October 14, 2008 Share Posted October 14, 2008 3 or 4 to one is usually the ratio for most resins. You will probably find that mixing the two together will give the right ratio by weight. It's not that critical - more hardener makes the finished resin set faster and harder but more brittle, less and the cure will be slower and the resin may stay flexible for some time. I use 5 minute epoxy a lot and vary the mix according to the properties I want. Quote Link to comment Share on other sites More sharing options...
Justin Needham Posted October 14, 2008 Author Share Posted October 14, 2008 Thanks then Bruce and Andy!Justin Quote Link to comment Share on other sites More sharing options...
Bob Howard Posted October 14, 2008 Share Posted October 14, 2008 They did 2 types of SP resin. If it is SP113 (it probably is) then 3parts resin to 1part hardener by volume. If it is SPX 5000, 5 parts resin to 2 parts hardener by volume OR 3:1 by weightI notice some shops are stocking SP113 again - it was good stuff.Re. Andy's suggestion about varying the mix :-With polyester (the smelly stuff from Halfords), all of the chemicals neeeded to effect a full cure are in the resin. The so-called "Hardener" is only a catalyst, which sets off the chemical reaction. More catalyst, quicker cure.With epoxy, each of the constituents contain a given quantity of the various chenmicals needed for a cure. If the ratio is not fairly accurate, some of the chemicals will remain in an uncured state. Too much hardener will result in a brittle mix with reduced strength, too little results in a cured resin a bit like cheese - soft & rubbery, again with little strength.Nowadays I use Deluxe Products Aeropoxy for skinning, mouldings and joining foam wings. If I remember rightly, the instruction leafelet suggests a maximum tolerance of 10% on the mix ratio (3:2 in this case), but I try to be spot on.For building, my policy is to always use a slow epoxy. Not only does it give longer to work with, but the joint is far stronger. I sometime stir a small amount of filler into the mix to add strength - either milled glass (from Great Planes) or Kevlar pulp (Fibretech). Quote Link to comment Share on other sites More sharing options...
