andy watson Posted October 19, 2008 Share Posted October 19, 2008 I have a futaba 2.4 gig 6EX transmitter, and a 617 receiver- no problems with it at all. The tx & rx are bound to each other, and work fine.But my tx has 6 model memories, and I am in the process of building my second plane. As I have already spent far more than I thought I would, I am quite keen to avoid spending more than I have to, and I wondered could I use the same receiver in both?So in essense can I have the same receiver set up as model 1 & 2 on my tx, presumably with the settings saved differently on both? Quote Link to comment Share on other sites More sharing options...
Mike Bell Posted October 19, 2008 Share Posted October 19, 2008 There should be no problem using the receiver in any number of planes. All the programming set up is in the transmitter, the receiver just does as it is told. Just make sure you select the correct program in the transmitter for the appropriate model.Mike Quote Link to comment Share on other sites More sharing options...
birdy Posted October 19, 2008 Share Posted October 19, 2008 You'll need to think of a crafty (ish) way of moving it around from plane to plane easily though. Quote Link to comment Share on other sites More sharing options...
andy watson Posted October 19, 2008 Author Share Posted October 19, 2008 velco.............and I'm £60ish richer!Cheers- I thought it would work, but someone at the club (with even less experience than me!) was swearing blind it wouldn't! Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 19, 2008 Share Posted October 19, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted October 19, 2008 Share Posted October 19, 2008 I currently have 7 airworthy airframes and only 2 receivers! The only problem is that the 6EX only has 6 memories.Just note down each models program details, label each servo lead and it only takes a few minutes to swap over an RX Quote Link to comment Share on other sites More sharing options...
birdy Posted October 21, 2008 Share Posted October 21, 2008 I was thinking more about reliably positioning arials without damaging them. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted October 21, 2008 Share Posted October 21, 2008 Just glue a thin tube ( drinking straw, paper tube etc) in the position of each aerial and they will be held in place and protected at the same time. Then you can just slide them out of one plane and into another. Quote Link to comment Share on other sites More sharing options...
