Tethered glider electricity generation?
I am sure it will generate power but only when it is letting out the tether so it is cyclic generation. In addition the power required to pull the line in again has to be deducted.
Given they claim it cycles automatically I would surmise it has a very complex auto guidance and stability system on board.
I find it hard to see any benefit of generating power like this. Does it generate as much power as a ground based wind turbine of the same span, which gives continuous and self starting generation.
I fear this is an ingenious technological solution looking for a problem.
