Patrick Posted March 20, 2023 Share Posted March 20, 2023 1 unit: £25 The Aerostar range of brushless speed controllers is designed for fixed-wing aircraft. They feature super smooth start-up, linear throttle response, and multiple protection features, all at a fantastic price. Although primarily designed for fixed-wing aircraft, they also include a soft start and heli mode, making them a good low-cost alternative ESC for your next helicopter project. Installation is very straightforward as these speed controllers come "plug & play", with no soldering required, they are pre-fitted with an XT60 connector and 3 x 3.5mm gold connectors. Programming can be done either using the transmitter and listening to the tones or you can use the dedicated programming card (see "Related Items"). Features: • Pre-installed motor and battery connections • Propeller Brake • Battery type (NiMH or lipo) • Low voltage cut-off • Adjustable motor timing • Soft start for gearboxes and helicopters • Heli mode • Motor rotation • Overheating and lost signal protection • Low voltage cut-off type Default settings: • Brake: Off • Battery type: Lipo (auto cell detect) • Low voltage cut-off: 3.2V (60%) • Timing: Automatic • Start-up acceleration: Soft • Heli mode: Off • Motor rotation: Normal • Frequency: 16Hz • Voltage cut-off: Reduce power Specs: Type: Aerostar 60amp electronic speed controller Input Voltage: 2~6 lipoly cells/5~18 NiMH cells (6~23V) Continuous Current: 60amps Burst Current: 70amps (10secs) BEC Output: 5.5V/5amps Programmable: Yes Dimensions: 56 x 30 x 14mm Weight: 44g Battery Connector: XT60 Motor Connectors: 3.5mm gold Rx Connector: JR type Lead Length: 270mm Quote Link to comment Share on other sites More sharing options...
