Patrick Posted March 20, 2023 Share Posted March 20, 2023 £15 Compatible with all DSM2/DSMX 2.4GHz Air transmitters and now featuring CPPM! The OrangeRx R615X takes things to the next level by offering CPPM, true DSMX compatibility, and utilizes dual antennae providing true signal reception diversity! Add to this programmable failsafe on binding, ultra-fast brown-out recovery, and wide voltage input range. The end result being an unbeatable value for money aircraft receiver! The all-new CPPM functionality is an excellent feature for use with multi-rotor flight controllers such as the KK2.1, APM, MultiWii, and others. This single line connection removes the weight and mess of additional wire leads for each individual channel. This is ideal for use on small frames where space is at a premium. OrangeRx receivers are built using original components, MCUs and with state of the art SMT automation to ensure a quality product each and every time. Every R615X is manufactured using impedance matched PCBs with exact tuning to provide signal stability and range that exceeds any of the previous generation ORX products. The R615X is a small lightweight receiver designed for small park fly aircraft and small quads, it is not a full range receiver. All R615X OrangeRx receivers are QC tested using our latest method that ensures range checking takes place as the receiver is programmed. Simply put, if the R615X cannot pass the range check criteria it cannot be programmed, this ensures 100% of R615X are guaranteed to work flawlessly. The R615X ushers in a new era of quality, reliability, and performance for the OrangeRX line up. Features: • Super lightweight 3.7g / 9.8 grams with case • Compatible with DSM2/DSMX 1024/2048 aircraft radio and module systems • CPPM output allowing for single line connection with compatible CPPM devices • Short 25mm antennae for mounting in almost any location • Wide input voltage: 3.7~9.6V • 6 Channels • Compact design Specification: Channels: 6 Input voltage: 3.7~9.6V Usage: Small park fly aircraft and mini quads Size: 19.5x30x10mm, 43x22x13mm with case Weight: 3.7g / 9.8g with case Quote Link to comment Share on other sites More sharing options...
