David Ashby - Moderator Posted August 20, 2007 Share Posted August 20, 2007 Hi Dave, just call our customer services on 01689 899200 opt.3 and they take care of it. David. Quote Link to comment Share on other sites More sharing options...
wlfk Posted September 6, 2007 Share Posted September 6, 2007 Just a quick question - looking forward to building this model.I sometimes build parts (tailfins for my helicopter) by glueing thin laminates together with cyano. This makes a very stiff section, without the weak joins that you get when you simply but the ends together (e.g. wing section in the EZEfan). Effectively, it's very lightweight ply, but with the grain directions arranged more carefully.This has a small weight penalty, but it's not more than a few grams and I like the stiff sections. Is there any good reason _not_ to do this?One concern is that if you get any moisture, the wing may warp more if the surface layer is laid in a different direction to the deep layer.K Quote Link to comment Share on other sites More sharing options...
wlfk Posted September 8, 2007 Share Posted September 8, 2007 Just a reply to my own post. I bought the balsa; built the plane (almost) according to the plans. And I'm impressed how stiff the construction is. Just need to get me some solarfilm and the electrics now.But another question... Does anyone add any ventilation for the battery?K Quote Link to comment Share on other sites More sharing options...
Colin Hooper Posted September 17, 2007 Share Posted September 17, 2007 I found that the fuselage did not give much scope for creating airflow around the battery. There is not much room for my Hyperion 1800mah in that confined space. I was more concerned to keep a good airflow over the ESC as I chose to put that into the fuselage as well. I therefore cut a slot into the bottom, alongside the skid, with a plastic spoon to create an air scoop. The outlet was created by putting a hole at the back of the fuselage pod. on the EDF unit's centre line. I reasoned that the fan would create a low pressure zone that would assist the air flow. (It also gave me a hole to tighten the fan screw if it ever came loose!)The model is an absolute rocket and experience has been limited, so far, by shakey knees. It does slow down nicely though and is a good glider, despite the fan. Quote Link to comment Share on other sites More sharing options...
Paulo Santos 2 Posted January 24, 2010 Share Posted January 24, 2010 Hello, i'm from Portugal, do you know where i can foun a digitalize plan of EZE-FAN. Please tell me something Paulo Quote Link to comment Share on other sites More sharing options...
