Futaba 7C 2.4GHZ - 6.0V RX Power
Nick Holmes 2
Speed:  .22 sec/60° @ 4.8V, .18 sec/60° @ 6V
Torque: 69 oz-in @ 4.8V, 87 oz-in @ 6V
Weight: 1.5oz (42g)
Length: 1.6" (41mm)
Width:  0.8" (20mm)
Height: 1.5" (38mm)
Remember that using 6V will use more power, so quite likely LESS duration for the same capacity 4 cell pack. The reciver is fine on 6V or even higher....and these are indeed 6V capable servos.
WHY do you want / need to use 6V ?
Thanks for the reply,  have put the servos, S3152's, into a Hanger 9 showtime 4d 90 which I was advised by TJD Models were good enough for the job,  however reading the Hanger 9 instructions it states they should be a minimum of 80oz torque hence me thinking I should use a 6v RX bettery toi give me 87oz-oin torque.  what do you think?.
Well just my opinion of course...but a stronger servo is probably better TBH.
The specs of the 3152 may well claim 87oz @ 6V, but remeber these torque figures are as measured at the innermost hole of the servo arm usually, and for a 3d machine especially, you may well end up using outer holes, or indeed longer than standard arms, with a resultant dropping in torque, the "further out" you go on the arm.
