Edward Ward Posted January 25, 2009 Share Posted January 25, 2009 I have acquired a Multiplex rx-6-synth light receiver to put into my twinstar2. I think I have locked it into my transmitter channel (64) ok as all the stick movements react through this receiver, but I am a bit concerned that the little led light on the receiver is continually flashing when the tx and rx are switched on. Is this mormal?. Please help, its first synth rx ted Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted January 25, 2009 Share Posted January 25, 2009 Hi Edward, If it is anything like the JR Synth rx, you have to press the reset button on the rx to lock-in the new frequency. Then the LED should be steady. Quote Link to comment Share on other sites More sharing options...
Martin&Sue Hardy Posted March 12, 2009 Share Posted March 12, 2009 Edward, In common with the other MPX synth receivers, it is correct for the LED to flash continuously with the tx and rx switched on. If it stays on constantly it is not receiving and needs to be locked on again. Quote Link to comment Share on other sites More sharing options...
