Bob Brown Posted September 11, 2024 Share Posted September 11, 2024 The 9g servo popup mount. This mount was designed to enable 9g servos to be installed into thin wings without the need for gluing which can cause problems when a servo needs to be replaced, or when the servo arm needs to be repositioned or replaced. There are 2 parts to the tilting mount, a fixed frame which is glued into the servo recess and a tilting frame which the servo is attached to and the pivot which is itself clamped to the fixed frame by 2 M2 self tapping screws. The whole assembly will fit into a 42 x40 x 12.5 deep pocket and the servo can then be replaced by simply removing the 2, M2 clamp screws, tilting the servo assembly upwards and removing the servo. The pocket depth is only limited by the thickness of the servo. Anyone with a 3d printer is welcome to make these for their own use, please click the following thingiverse link. https://www.thingiverse.com/thing:6721166 5 Quote Link to comment Share on other sites More sharing options...
