Bob Gray Posted February 8, 2009 Share Posted February 8, 2009 Hi All In October last year Paul Newell asked if the two aileron outputs of the AR500 are a simple Y type connection or separately programmable from, typically a DX7 to give flaperon or brake facilities. He got two answers in opersite directions, i.e. he got one vote for each. Can anyone give a definetive answer please. Bob Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 8, 2009 Share Posted February 8, 2009 Simple Y type dual connection. Quote Link to comment Share on other sites More sharing options...
Bob Gray Posted February 8, 2009 Author Share Posted February 8, 2009 Thanks Timbo, I hope Paul is checking. Bob Quote Link to comment Share on other sites More sharing options...
Pete Norris Posted February 10, 2009 Share Posted February 10, 2009 can i use an AR500 5th channel for landing gear Pete Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 10, 2009 Share Posted February 10, 2009 It is a 5 channel rx - so if you are using all 5 functions already then no - the "extra aielron channel is "Y" leaded to the other aileron channel internally, however there is a dedicated gear channel. To clarify ( I hope ) thr ail (1) ele rudd gear ail (2) Quote Link to comment Share on other sites More sharing options...
Eric Strefford Posted February 22, 2009 Share Posted February 22, 2009 This receiver does have a 5th channel for gear as well as the additional outlet for another aileron servo. Just bought one and checked it out on the bench. You are correct in that the additional aileron channel is effectively a Y lead so you cannot reverse the additional aileron servo you will have to check direction etc the old way by linkage setup. Hope this clarifies matters. Eric Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 22, 2009 Share Posted February 22, 2009 just posted about this on another thread Have also ( hopefully) clarified things better in my post above - sorry for the confusion. The "manual" that accompanies the Rx is, as often, rubbish in explaining things. Quote Link to comment Share on other sites More sharing options...
