001 Posted May 20, 2007 Share Posted May 20, 2007 I have three Futaba Transmitters, the second oldest one a well used but reliable FF6 was being used regularly until about two months ago, meanwhile I have been using a newer transmitter. In the 6exa there were three models in its memory, 1, on PCM, 2 and 3 on PPM I only have one PCM receiver and that has been in the same model for about two years and never taken out.When I switched the transmitter on again today, all three channels were set to PCM!No I have not been playing with model copy or removed the battery or anything else. When stored, the channels were as stated. I do not see how this is possible.I am now concerned in case this happens while I am flying. Any comments. Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted May 21, 2007 Share Posted May 21, 2007 Mobile phone used nearby?Mike Quote Link to comment Share on other sites More sharing options...
001 Posted May 21, 2007 Author Share Posted May 21, 2007 Hello Mike, where I have lived for the last 4 years there is no mobile phone coverage at all. Where I fly there is, but, the transmitter has been in the same room in my house for 2 months together with the 6EXA transmitter I use more frequently, this has not been affected. On the other side of the room (about 3 metres away) is the main electric meter for the house and a switch unit for off peak electricity which I believe is operated by a radio signal, this can be heard to switch off in the morning. I am wondering if the transmitters could be affected by a 'spike' in the 240v. supply. I never considered that until you mentioned mobile phones.I think that more investigation is needed. Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted May 21, 2007 Share Posted May 21, 2007 RichardIf you manage to find the cause dp let us know. Best of luckMike Quote Link to comment Share on other sites More sharing options...
