Peter Beeney Posted December 3, 2024 Share Posted December 3, 2024 Chris, I’m sorry about your UBECs, that must have been bit of a shock at the time, to say the least. I’m not sure that I’ve ever mentioned UBECs, so far I’ve never had a run in with any of these yet but I will do so as soon as I get the opportunity. As far as proving a point goes I’ve only ever done this sort of stuff just to find out what I consider really happens; the results themselves proved the point, I didn’t…… I certainly wouldn’t advise anyone to not disconnect any red wires but if they wanted to leave them intact simply because that’s what I do then that would be their prerogative. Why do you think the tests are biased? I try and make them as firm as I can without going overboard; witness the 7V stress test. I could have gone higher, 107V even, but that would/could have been just wanton destruction. I used a variable bench supply so I turned the current supply wick right down to just a few milliamps limit so in the event of something going short circuit things would not start getting hot. Max safety throughout. I will return in due course with some new facts and figures as a result of tinkering with some new kit. PB Quote Link to comment Share on other sites More sharing options...
Peter Beeney Posted December 14, 2024 Share Posted December 14, 2024 Just to add another paragraph to this thread can I say I’ve now connected two brand new SBECs (switch-mode voltage regulator) in parallel and they’ve been more than happy in each other’s company for 8 hours. However, at the moment it is a bit of a ‘cobbled together’ tangle of components, wire, safety pins and sticky tape… but already I’d be happy to leave it for 8 days if necessary. If any one is at all interested I’d be pleased to give this combo a good all round workout on a load frame and find out just how good they are at working properly together. They’re quite versatile, up to 36V input, 8S, with a 5A max output at 3 voltage settings, 5, 6 and 7.4 volts, so quite a few variations. A complete MO with volt, amp and temperature readings and anything else I can think of. It would have to wait for a little while though, I’m going to be fairly busy for a time over the Xmas and New Year. PB Quote Link to comment Share on other sites More sharing options...
