ken anderson. Posted March 2, 2009 Share Posted March 2, 2009 i think i've just killed my fairly new nmh receiver battery--i've been setting up a new model(acrowot) ready for the big day and gone and left the electric's switched on-when iv'e gone back to it aprox two day's it's completley flat(kaputski)---i understand that once they are flattened they are done for/reverse's the inside--can anybody confirm if i'm right or wrong please?? thankyou ken anderson........... Quote Link to comment Share on other sites More sharing options...
Malcolm Fisher Posted March 2, 2009 Share Posted March 2, 2009 Try to recharge, and see what happens. If you have a charger which can do a charge/discharge cycle, that might tell you whether the capacity is reduced or not, and by how much. I've left NiCd batteries in the same way you have done, and they seem to be OK after "cycling". No experience of NiMH in that situation. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 2, 2009 Share Posted March 2, 2009 It should be OK - its LiPo that mustn't be left to drain empty. Do as Malcolm says. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 2, 2009 Author Share Posted March 2, 2009 just had a look at a couple of articles on the net-and also some of that fellow who go'es by the name of timbo's word's of wisdom---look's like the battery is done for ken anderson-battery killer ps------------could timbo be the stigg off top gear???--there is a mystery Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 2, 2009 Share Posted March 2, 2009 You obviously havent seen me in a racing suit ken Quote Link to comment Share on other sites More sharing options...
Chris C Posted March 2, 2009 Share Posted March 2, 2009 :P:P Quote Link to comment Share on other sites More sharing options...
nasa_steve Posted March 2, 2009 Share Posted March 2, 2009 the battery should be fine give it a long deep charge/discharge cycle and it should be ok nasa Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 3, 2009 Share Posted March 3, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 3, 2009 Share Posted March 3, 2009 Do they ? I must say I have not come across these ( however I dont generally buy /use Nickel based packs these days ) However, the last ones I did buy a few weeks ago had no such PCM - although these devices are quite common in some Lithium packs. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 9, 2009 Author Share Posted March 9, 2009 can anybody tell me what to do with 3 nicad fast charger's that until recently were the bee's knee's-now i take it they are dinosaur's--no p.m's or funny reply's as to where to put them thank's................. ken anderson. Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted March 9, 2009 Share Posted March 9, 2009 Ken, give them to me !!!!! Chris. All donations gratefully received Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 9, 2009 Share Posted March 9, 2009 You can still use them on NiMH if you make sure the packs are removed when full.., the charge process is the same its just the delta peak detect thats different. Quote Link to comment Share on other sites More sharing options...
