Andy Harris Posted March 6, 2009 Share Posted March 6, 2009 On my Son's DX6i we created a 'model' for the FreeBee and one for the Mini Pulse. Now we find that the Pulse doesn't work and the FreeBee setting is 'bound' to both models. Oddly enough the trims on both models are so close it doesn't matter in practical use. However I thought this should not be possible. Andy Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 7, 2009 Share Posted March 7, 2009 It is quite possible to bind as many models as you like to the same transmitter - however each model has to be put through the correct bind sequence, maybe you inadvertently "copied" the one to the other? Quote Link to comment Share on other sites More sharing options...
David E Posted March 11, 2009 Share Posted March 11, 2009 I'm wondering how bulletproof the DSM2 system really is - at our club indoor meetings, I sometimes hear complaints that DSM2 a/c such as Ember 2s, Vapors and MCXs are getting connected to other people's transmitters when they are switched on. What are other people's experiences with this kind of thing? Is it just a problem with the cheapy LP4DSM Tx? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 11, 2009 Share Posted March 11, 2009 I suggest that it is procedural rather than a "fault" Bear in mind that the binding procedure for the Vapors and MCXs etc is easier and more likely to be done accidentally than regualr Spektrum Rx. Anyone switching on a Vapor etc before the Tx has effectively put the model in bind mode - no bind plugs etc to do on these simple models. I have a vapor and a blade mcx and have never experienced any sush issues - also was at an indoor session last night with at least half a dozen of these things flying around and changing batteries etc - no problems whatsoever. DSM2 does not differ from DSM(1) in the way that model memory and binding takes place - it merely reflects better and faster signal diversity and reception. Quote Link to comment Share on other sites More sharing options...
David E Posted March 11, 2009 Share Posted March 11, 2009 Yeah, I guess that could be the problem. I'd hope for better from fellow fliers though - could be pretty nasty with outdoor models. Quote Link to comment Share on other sites More sharing options...
Paul Course Posted March 11, 2009 Share Posted March 11, 2009 Had a similar problem with my mcx it soft landed twice after changing the battery for a fully charged one it also seems slow to find the tx on occasions, this seems to be worse when my son is messing on his pc through the livebox, or could that just be me ???. Good excuse to get him to do his homework though. (daddy needs his practice) also just cant seem to get adding different models to the dx6i right (any chance of a tutorial) pictures are good for us birmingham screwdriver experts!!!!!!! TA Quote Link to comment Share on other sites More sharing options...
Andy Harris Posted March 14, 2009 Author Share Posted March 14, 2009 I did post a reply, but it got lost! I was thinking that the internal organisation and model match would mean that there would be one RX bound to each preset. As an aside I can't find a date code on the DX6i but it seems to behave perfectly on the monitor screen. Quote Link to comment Share on other sites More sharing options...
David E Posted March 16, 2009 Share Posted March 16, 2009 I have heard that it is possible to bind multiple MCXs to the same transmitter intentionally, so that they fly sychronised. Perhaps this is achieved by placing them all in bind mode and then turning on the Tx. I wonder if this is what happend with your two models, Andy? Could the first model have been unintentionally placed in bind mode when the second one was bound? I'm slightly unclear about how Model Match works exactly. Unless there is two way communication, it seems hard to imagine that it's impossible to bind two models to the same memory simultaneously. Perhaps the Tx generates a unique ID that the Rx is told to respond to each time binding occurs, so that if a second model is bound, the first one stops responding. However, if both are bound at the same time, they would both be set to respond to the same ID. Have you tried rebinding them both to seperate model memories? I heard that DX6i Txs witout date codes are not affected by the recall. Quote Link to comment Share on other sites More sharing options...
Chris Hockaday ( East R/C ) Posted June 20, 2009 Share Posted June 20, 2009 You can bind multiple receivers to one model memory. I use Five (5) AR-6200's in a 12 Foot Telemaster with my DX-7. No extensions anywhere. It's nice for setting up a large airplane at the field. Bolt everything up, flip the switches, fly. Quote Link to comment Share on other sites More sharing options...
