JC Posted March 22, 2009 Share Posted March 22, 2009 Hi all Ive put a E Flite park 370 4100Kv motor in my Toucan. I,m using a 2s 1300Mh 15c lipo turning a graupner folding 6-3 prop and a 30amp esc. On running the motor to check everthing out, it became too hot to touch after only running for 20 seconds or so on half throttle. Is this normal. I,m afraid I'm still not completely sure about using the correct prop to motor to battery and ESC. All advice welcome. Regards Jon Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted March 22, 2009 Share Posted March 22, 2009 Once again......proof of the value of a wattmeter! Jon, 4100kv is pretty wild, even on 2s for a 6" prop, it's almost certainly over-propped, the E-Flight 370 is only good for 10-12A I would have thought. You need to start with probably a 4" prop, a watt-meter and go from there. Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted March 22, 2009 Share Posted March 22, 2009 Your motor is trying to spin that prop at about 32000 RPM at full throttle which is too fast. I think you need a motor a a lower KV. I always aim for about 8-10000 RPM so 2s you need something like a 1200-1500KV motor. However your prop is small so maybe aim for 20000rpm so on 2s you need 2500-3000 KV. This is a very simplistic view but it works for me. Edited By Bruce Richards on 22/03/2009 14:34:24Edited By Bruce Richards on 22/03/2009 14:34:55 Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 22, 2009 Share Posted March 22, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
JC Posted March 23, 2009 Author Share Posted March 23, 2009 Gents Thanks to you all. It appears that all inrunners seem to be high KV motors is this the case? The aircraft was designed for a brushed 400. So I will modify the nose section to take an out runner with a 1400 KV rating that I have. Any suggestions for a good WATT meter that wont cost the earth. Thanks again Regards Jon Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 23, 2009 Share Posted March 23, 2009 Pretty much yes Jon. Try this Quote Link to comment Share on other sites More sharing options...
JC Posted March 23, 2009 Author Share Posted March 23, 2009 Thanks again Timbo. Jon Quote Link to comment Share on other sites More sharing options...
JC Posted March 23, 2009 Author Share Posted March 23, 2009 Just as an after word I changed the prop for a 4'' gunther from my easy star spares and the motor still became very hot. How small a prop is small 370 4100Kv motor designed to swing and what sort of model would it be used on. Cheers Jon Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 23, 2009 Share Posted March 23, 2009 That is a bit surprising as 4100 motor wuld normally be spinning a 3 blade EDF Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted March 25, 2009 Share Posted March 25, 2009 The Gunther is for low rpm and will pull a lot more amps than, for instance, a Hyper Drive prop of the same size. Quote Link to comment Share on other sites More sharing options...
JC Posted April 19, 2009 Author Share Posted April 19, 2009 Timbo Just a quick one on the watt meter front. Where does it connect into the power train. On ALs Hobbies online shop it states connect it between the motor and ESC where as I have seen other references that say to connect it between the BTY and ESC. Are there different types of meter and if so which is the best? Cheers Jon Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 19, 2009 Share Posted April 19, 2009 Battery and ESC Quote Link to comment Share on other sites More sharing options...
JC Posted April 19, 2009 Author Share Posted April 19, 2009 Thanks Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted April 19, 2009 Share Posted April 19, 2009 Jon, How about a CHEAPER watt meter! Quote Link to comment Share on other sites More sharing options...
JC Posted April 21, 2009 Author Share Posted April 21, 2009 Cheers Ben. Puffin Models are out of stock. Jon Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 21, 2009 Share Posted April 21, 2009 Yeh nice find Ben. Quote Link to comment Share on other sites More sharing options...
Ron van Sommeren Posted April 22, 2009 Share Posted April 22, 2009 $3 diy wattmeter http://www.rcgroups.com/forums/showthread.php?t=949923 Vriendelijke groeten Ron Quote Link to comment Share on other sites More sharing options...
