Phil Claridge Posted April 21, 2009 Share Posted April 21, 2009 i think this question will be for our resident sage sir timbo, i have just got a sea fury and i have fitted an ar7000 rx but i have a dx6i tranny and i cant figure out how to get the flaps working independantly for the elevators do the servo's plug in to aux 1 or aux 2. next question the elevator is two piece on two servo's can i use aux 1 or aux 2 to slave with the elevator channel. i must admit i am a bit of a dumb nut on programming tranny's but i have found the dx6i easier than my old ff7 thank for any help you can give me regards phil Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 21, 2009 Share Posted April 21, 2009 Hi Phil. Not sure what you mean by flaps independantly for the elevators? Are you using flapperons or seperate actual flaps on the wing? If it is flapperons, then use aux 1 and aileron channel, having first set up wing mix to flapperons in system menu. In this case, for mixing elevators, you will need to use aux 2, (or indeed any spare channel) and simply use a free mix to couple it to elevator. You could of course just Y lead the 2 x servos for elevators. Cant remember off hand how many mixes there are in the DX6i...perhaps its only 2 - my DX7 has 6 free and two fixed. I think Edited By Timbo - Moderator on 21/04/2009 11:15:38 Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted April 22, 2009 Author Share Posted April 22, 2009 hi timbo what i meant was flaps independant from the elevators . the elevators are working on two servo's that are mirror image so if i connect them together they work like ailerons ,the manual says you can mix one channel with any other or with its self what i hoped to do was mix elevator with elevator slave but reverse one servo but i think my easiest option is to move one servo and use the oposite arm as the three servo's for rudder and elevator are close together, the ailerons are on a y lead because i have only one aux channel spare . i will have another go at programming the tranny later thanks for your help regards phil Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted April 23, 2009 Author Share Posted April 23, 2009 promblem sorted i only have 6 channels on the dx6i and their all in use so i will move one servo and fit a y lead still got to figure out the programming though Quote Link to comment Share on other sites More sharing options...
