Phil Winks Posted April 30, 2009 Share Posted April 30, 2009 Hi all I'm currently amongst other things looking for a home for two 12a 1400kv brushless motors. I fancy a twin and with the right airframe recon I can go to about 3lbs does any one know the expected AUW of Tony's aerovan Quote Link to comment Share on other sites More sharing options...
Mowerman Posted April 30, 2009 Share Posted April 30, 2009 The weight stated on the plan is 40oz (1.10kg) Wing Loading 12oz/sq ft (3.3kg/ms) Quote Link to comment Share on other sites More sharing options...
Ben Mullins Posted April 30, 2009 Share Posted April 30, 2009 I was thinking of making a tri-motor version of this, with the third motor in the tail, trislander esq. It would be powered buuy 3 permax 400's which im in possesion of. Or take the stuff out of that Skyvan I had and use that. Who Knows. Tell us how you get on Phil. Quote Link to comment Share on other sites More sharing options...
Glenn Howcroft Posted April 30, 2009 Share Posted April 30, 2009 Hi all .. You should give it a go Phil. I built one when the plan originally came out, but modified the power train. I used a pair of jamara 480s with irvine 400 gearboxes and 9x6 APC-E props. battery was a 10 cell pack of Cp-1700s . Power was excellent ..a real fun plane for little cost. I was looking over the original plan a few weeks ago and was thinking of doing a brushless version myself, let us know how you get on ... Glenn Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted May 1, 2009 Author Share Posted May 1, 2009 Thanks for that folks I have since found this on Tony's web site and I see he's recomending two 220w motors which seems a little over the top for a 2lb model to me must be a proper pocket rocket with those motors in I regularly fly a 600 gram model with one 130w motor in it so would've thought two would comfortably fly a 1kg/2.2lb er. the idea of a trilander esq version is intriging but what a pile of btys you'd need. I thought may be stick islander style u/c on and may be for fun equip with bomb bay doors for a para drop or something. Quote Link to comment Share on other sites More sharing options...
Terry Whiting Posted July 28, 2009 Share Posted July 28, 2009 Phil, I built one when it first came out, flew beautifully on two 400 can motors, have since revamped it with two BRC 130W combo's, the £12 outfits. Even with these the power is over the top. It's a cheap, and simple model to build, but a real pleasure to fly, you'll love it. Quote Link to comment Share on other sites More sharing options...
Steve Barton Posted August 4, 2009 Share Posted August 4, 2009 Phil, this was the plane I learnt to fly with and is my all time favourite. It is stable inverted and lands like a feather. I was a bit rough with it so for the second wing I built I extended the balsa covered section and added a little glass across the middle. I ploughed a few fields with it and it usually came up laughing. The only trouble I faced was with brushed motors - the soldered wires at the motor kept breaking off from the vibration. If that ever happens shut the other motor down straight away as you won't be able to fly on one motor. Brushed motors did not have the solder breaking problem and that would be the only way to go. I used two Robbe BL 2827-34, which was a tight fit but okay after a bit of fiddling. It certainly had heaps of go. I also used a 3000 3S because a 2200 ran out of oomph too quickly. 10 NiMH cells 2200 were ok if I had nothing else to use, but a tad heavy and not so sparkling a flight Without undercarriage it takes off from the snow and landing is a hoot. With a firm push it will do the same off wet grass . Hope you have as much fun as I did with it.Edited By Stevefromoz on 04/08/2009 16:04:55 Quote Link to comment Share on other sites More sharing options...
Gordon Nicol Posted March 26, 2012 Share Posted March 26, 2012 Anyone used 6mm depron to build this yet..... Its my material of choice at the moment, having just about finished my version of "the twins" from RC Groups free download...... I built aerovan when it was first published and still have the Fuz in the loft, but as i said depron for me this time, and another 2 emax motors , which will be more than powerful enough Quote Link to comment Share on other sites More sharing options...
