HELP -- YT Iconic EP
Dear Forum
I've started a build of the Iconic EP:
http://www.ytinternational.co.uk/Iconic_ep.htm
I've found that the firewall is perfectly perpendicular in both directions.  Whilst I can believe that no up/down thrust is needed, I find it hard to believe that no side thrust is required.
I thought that the manual would have suggested some washers somewhere but this is not the case.
I've assembled 25 models so far and I've never come across zero side thrust.
Could any one point me in the right direction ?  Have you flown an Iconic EP? Did you introduce side thrust ?
Many Thanks
Andy
build it straight from the box if the instructions don't say side thrust then don't put it in. YT models are jigged to build from the box...........why not ring wilson from YT his phone number is on the YT website. if not whay not go to the YT forum also on their website. failing that RCMF do have a YT forum in the "in the model shop" section
nasa
