John Bunting Posted July 1, 2007 Share Posted July 1, 2007 I see one or two retailers are now selling portable 'jump-start' units for £20. These might be useful for on-the-field chargers. They have a 17 Ah lead/acid battery, which should be enough to charge an average model several times, using a 12v. input charger such as a Shark 10. You can reduce the size and weight a bit by taking out the jump leads and inflator pump if you don't need them. Quote Link to comment Share on other sites More sharing options...
Mike Rolls Posted July 1, 2007 Share Posted July 1, 2007 I've used one successfully in the past for field charging NiCads and NiMH battereis - don't field charge Li-pos because they take so long.One thing - the Sculze Chameleon charger doesn't like them - it needs (buried in the instructions somewhere) a minimum battery capacity of somethng like 60AH. I tried using my Chameleon with the jump start battery and it stopped charging half way through with a message something like 'Insufficient battery' - I forget the exact words but the message was clear.MikeMike Quote Link to comment Share on other sites More sharing options...
