Ian Southerton 1 Posted September 5, 2013 Share Posted September 5, 2013 Hi, I'm new to flying, so excuse my lack of experience! To be honest, it struggles vertical as if there's not enough power or too much weight, but handles nicely for a beginner like me. I tried a roll and to fly inverted but can't remember what happened-it must have dropped and I panicked and nose dived into the ground. I built a new lighter fuselage and have had a couple of flights with this (been too windy to fly with my lack of experience) and it seems twitchy, but the jazz flies slower now. I think I prefered it with the extra weight!! Anyhow, I've ordered enough balsa to build 2 models, and plan to put a larger motor in (fits in with your moto!!), what difference would moving the cog back make to the handling? Cheers, Ian. Quote Link to comment Share on other sites More sharing options...
crispin church Posted September 9, 2013 Share Posted September 9, 2013 sounds like your too far back now twitchy is a sign only go up to .30 as anything else too heavy more power not all ways a good thing try different size and pitched props mine is 1.5kg with a os .15 in Quote Link to comment Share on other sites More sharing options...
Malcolm Corbin Posted September 9, 2013 Share Posted September 9, 2013 Crispin. 1,500 grams what did you build it out of!! Mine is OS 15 powered with a Weston mini pipe and weighs 855 grams. Ian as forgiving as a mini Jazz is a high wing trainer might be better to start with. Also the heavier they are the harder they will be to fly... that goes for anything that flies Malcolm Quote Link to comment Share on other sites More sharing options...
Malcolm Corbin Posted September 10, 2013 Share Posted September 10, 2013 Posted by Ian Southerton 1 on 26/07/2013 20:51:39: Hi Finally flew my electric mimi jazz, have a turnigy d2836-8 1100kv motor, 40a esc and a 1500mah lipo. Cog is 65mm back, but i had to put around 200grams in the nose-anybody else found this? Ian. Mine is COG 65mm too. Not your problem. Sounds like you are a beginner and probably a heavy model too. What does yours weigh ? Quote Link to comment Share on other sites More sharing options...
crispin church Posted September 11, 2013 Share Posted September 11, 2013 my cog was 70mm which is just a bit too twitchy have added a little lead but have not flown yet too many others but it is a great plane all ways in my ready to go list Quote Link to comment Share on other sites More sharing options...
Malcolm Corbin Posted September 11, 2013 Share Posted September 11, 2013 Mine (CG) is 65mm too. Ian how much does yours weigh? Quote Link to comment Share on other sites More sharing options...
Ian Southerton 1 Posted September 23, 2013 Share Posted September 23, 2013 Sorry for the slow response, musr look at the site more often! AUW was 2lb 5oz or 1040 grams, unfortunately it now weighs about 2lbs as the other 5oz is stuck in the ground after i crashed it-however, i've nearly built another mini jazz with made up elevator instead of solid, plastic snake pushrods, light balsa etc so hopefully i should be able to keep the weight down. Only thought now is whether to mount the aileron servos on top of the wing and not use undercarriage as the grass is always too long for take offs and landings-any suggestions? Malcom, if you were to design another plane, how about a mini jazz with a high wing, more stable for novices like myself, but will still look good and fit in the boot of a small hatchback! Thanks, Ian. Quote Link to comment Share on other sites More sharing options...
Ian Southerton 1 Posted September 24, 2013 Share Posted September 24, 2013 Posted by Malcolm Corbin on 28/07/2013 22:15:17: How did it fly ? Did you try inverted if yes was stick neutral or did you have to push down in?? My moto.... "Never add weight. Fit bigger motor" OR bigger Li poly CG is very much a personal thing!!!! Some of the display boys in the sandown era flew model with such rearward CG you would be amazed !! Tried flying inverted briefly today and i have to use a lot of down elevator, out of curiosity, why did you ask? Quote Link to comment Share on other sites More sharing options...
Malcolm Corbin Posted September 29, 2013 Share Posted September 29, 2013 If you are pushing down when inverted your CG is to far forward... Quote Link to comment Share on other sites More sharing options...
Ian Southerton 1 Posted September 29, 2013 Share Posted September 29, 2013 I've been flying my repaired jazz whenever possible, but i messed up when i built it and the tail fin is too far forward. Anyway, Friday, i had to keep pushing the nose down at it kept lifting up into a head wind, i tried inverted a few times and felt it needed less down elevator to stop the nose dropping! I seem to get different results every time i fly! The newly built jazz should be finished soon a little lighter and with a more powerful motor, i'm just deciding whether to spend £27 on a cowl and canopy-seems pricey? Anway thanks for all the replies and advice. Ian. Quote Link to comment Share on other sites More sharing options...
crispin church Posted September 29, 2013 Share Posted September 29, 2013 for canopy make a wooden plug and use a hoover and a heat gun vac form your own i made 2 for my jaz Quote Link to comment Share on other sites More sharing options...
Ian Southerton 1 Posted September 29, 2013 Share Posted September 29, 2013 Just treated myself to a canopy and cowl! Ironically, this morning i got the plastic cover off some tesco croissants and the wife,s hair dryer, and melted it over a tin of beans to see if it woukd mould. I may use the genuine parts as a guide to make a copy! Any pics of yours? Ian. Quote Link to comment Share on other sites More sharing options...
crispin church Posted September 30, 2013 Share Posted September 30, 2013 Quote Link to comment Share on other sites More sharing options...
Ian Southerton 1 Posted October 3, 2013 Share Posted October 3, 2013 I've received the canopy and cowl and am not too impressed for the £27 it cost me, the return postage was only £2.40 so the packing must have been expensive! Before i cut them to fit, i made a plaster mould of the insides. I noticed this morning, the wife had bought some Tesco croissants with the nice clear plastic lid, so may spend some time with my 8 year old and the wife's hair dryer to see if I can make a canopy! I've had to sand a lot of material to get the nose cone and the canopy to fit, so i can understand how Malcom's jazz weighed 7oz bare and mine weighed 8. What's the best way to fix the canopy and cowl?. Ian. Quote Link to comment Share on other sites More sharing options...
