Securing Cockpit Bubble?
Whats the accepted way of securing the cockpit plastic on a glider for repeated access to battery?
The glider im restoring had the bubble permanently glued on which was daft as it meant no access for battery location.
I was planning on hinging one side with tape but don't know how the otherside is secured for constant access?
Mike,
I used a small roundhead screw at the leading and trailing edges of the cockpit aperture with matching notched in the plastic canopy. To fit, just flex the edges out and the length of the canopy shortens enough to spring into place under the screwheads. Removal is the reverse, perhaps needing a flat lever (6" rule, Swann Morten handle, flat screwdriver blade, etc) under one edge to flex it enough to get a finger under it.
This will only work with a frameless canopy.
