Streetburner Posted October 28, 2009 Share Posted October 28, 2009 When connecting aileron servos to receiver it says connect right one to aileron & left one to aux1 on receiver. DX7 tranny. When I switch on etc, only one works when stick is moved but power is to both what am I doing wrong or should I fit a Y lead and connect both to aileron on receiver. Was trying to avoid doing this (more wires) Help appreciated still learning. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 28, 2009 Share Posted October 28, 2009 Separate aileron control is only useable if you tell your tx that you are using either flapperon or delta wing mixing. Have you done this in the Tx menu?If you use a Y lead, then you will not need this mix, but of course, you will not have the flexibility of flaperons /delta Quote Link to comment Share on other sites More sharing options...
Streetburner Posted October 29, 2009 Author Share Posted October 29, 2009 Thanks for the reply, have set TX up properly now, easy peasy when you know what to do. Thanks again! Quote Link to comment Share on other sites More sharing options...
