Chris Perkins Posted November 10, 2009 Share Posted November 10, 2009 HI, Ive recently bort an eflight mini edge 540 for a little thing to play which with out too much effort and as it was second hand so it didnt cost too much. but when it came to checking the motor upon getting to about half throttel the prop began to vibrate violently, could this because that the prop is not balenced. It is a standard eflight prop that the plane came with thank chris Edited By Chris Perkins on 10/11/2009 19:14:59 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 10, 2009 Share Posted November 10, 2009 hello chris-prob one of two thing's-the prop is in desperate need of balancing or the spinner is the same......also is it not that the spinner is off centre or the shaft of the motor is bent(that's four thing's... ..) try running the motor with no prop on..if it's the shaft bent you will see it/feel it----put on the prop c/w no spinner do the same again..until you determine what it is...if still no luck-try a different prop and prop adaptor....... hope this help's ken anderson.................. Quote Link to comment Share on other sites More sharing options...
Chris Perkins Posted November 10, 2009 Author Share Posted November 10, 2009 thanks ken ill give it try tomorrow and tell you the out come chris Quote Link to comment Share on other sites More sharing options...
Chris Perkins Posted November 11, 2009 Author Share Posted November 11, 2009 Ive had a look at the edge and its looks like its the prop being out of balance thanks for the the advice. chris Quote Link to comment Share on other sites More sharing options...
