Olly P Posted November 13, 2009 Share Posted November 13, 2009 As you may havee seen in my other thread I was having problems with my ESC's (mostly on programming movement). This has however led me to discover a different problem with my Tx. I have taken Phil's suggestion from the other thread of trying a servo in each channel and seeing what happens. All mixes are INH (switchedoff). For every channel on the set 1-6 the right hand stick (airlerons (CH1), and elevator (Ch2)) moves all 6 ports on the Rx. The throttle/rudder stick does nothing, the flap knob works only on the correct channel but alongside the right stick, and the gear switch has no effect. I am seriously confused and on the verge of throwing this out of the window. I don't have a second reciever to test this with. ANY suggestions appreciated. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 13, 2009 Share Posted November 13, 2009 Does it behave like this in non ESC configuration also, EG: normal rx battery supply? If so, it sounds like a poorly Tx.Aero mode, no flight modes setup, and Wing mix all set to normal I presume? Edited By Timbo - Administrator on 13/11/2009 12:30:13 Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 13, 2009 Author Share Posted November 13, 2009 Tim - Yes, with normal Rx battery. Aero mode, no extra modes or mixes. This could get expensive.... Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 13, 2009 Share Posted November 13, 2009 Well then if if you are absolutely certain that all is "normal" then I must conclude the Tx is a duffer. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 13, 2009 Share Posted November 13, 2009 Sounds like a good time to ask for a nice new 2.4G set for Xmas! Quote Link to comment Share on other sites More sharing options...
andy watson Posted November 13, 2009 Share Posted November 13, 2009 If I remember you are in Blackburn.Accrington- 10 minutes away from me if you want to borrow a 2nd receiver to test on. Send a PM if it will help. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 13, 2009 Share Posted November 13, 2009 Indeed - should eliminate the Rx before splashing out on a new Tx! Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 13, 2009 Author Share Posted November 13, 2009 Andy - I am indeed in Blackburn, well Rishton, I'll PM you shortly! Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 13, 2009 Author Share Posted November 13, 2009 Timbo - Xmas pressie sounds great but was hoping to get my T180 into a flyable condition today, and up tomorrow! Ah well, I can still finish the tail off (Now I've found the missing bit) Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 14, 2009 Author Share Posted November 14, 2009 Ignore me - I'm an idiot. The Tx was set to PCM, the Rx is only PPM capable. I have now switched it for perfect operation Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 14, 2009 Share Posted November 14, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 14, 2009 Author Share Posted November 14, 2009 Only closing the thread down phil.... Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 14, 2009 Author Share Posted November 14, 2009 I did put in other thread.... Arnie I'm going to redesignate my T180 as a T1000 Quote Link to comment Share on other sites More sharing options...
Olly P Posted November 14, 2009 Author Share Posted November 14, 2009 No probs Polnotasconfusedasolly Quote Link to comment Share on other sites More sharing options...
