Leslie Broome Posted July 16, 2007 Share Posted July 16, 2007 can someone please give me some advice.had anew SKYLANE ep fore birthday 1st electric. came with a 400 geared motor.ive got ajeti 4channel receiver (REX 4MPD)and a7cell 1050 batt can someone tell me if this is compatableand what E.S.C. i could use Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted July 17, 2007 Share Posted July 17, 2007 A 400 geared motor will take a lot more voltage than that, but I must admit, I'm not familliar with the air-frame. ESC will be largely determined by prop size, did one come with the kit, if so, what size is it? Quote Link to comment Share on other sites More sharing options...
Leslie Broome Posted July 17, 2007 Author Share Posted July 17, 2007 prop came with kit. its afolding one about 93/4 inches . just found wing span 1040mm fuselagelength 760 mm flying weight 26 oz. just found in instructions 1000mah batt needed does that sound ok.thanks verry much for taking trouble look forward to hearing from you again scott les broome. Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted July 17, 2007 Share Posted July 17, 2007 The rule with ESC's is if in doubt....or even if your not in doubt....add a safety margin!This doesn't sound like a particularly quick flyer, so, I'd use the set up you have, and chances are a 20A speed control would be enough....so go with a 25A! [you don't say what pitch the prop is, so I'm basing this on experience wit park flyers]I would advice going with an brushed ESC that is Lipo compatible [usually via a jumper plug], that way, when you have decided that you have become bored [or not....] with the standard set up, switching to a 3s [11.1v] Lipo will give you a whole new experience! Not to mention more endurance [a 2100mAh Lipo will give more power, twice the endurance....and basically weighs the same!]. Quote Link to comment Share on other sites More sharing options...
Leslie Broome Posted July 17, 2007 Author Share Posted July 17, 2007 many thanks scott.your advice sounds very good to me i willtry what i,ve got and se how we get on from there Quote Link to comment Share on other sites More sharing options...
