Mike Downs Posted July 19, 2007 Share Posted July 19, 2007 Hi, Help please with a problem!I have been powering a small chuck model with a BM2403-21 Bell type powered by a Tornado 2S 1200 with a APC 7x5 E... The problem is a few seconds after launch the power fades If I run the model in my hand this does not happen ! Ideas anyone please Cheers John Quote Link to comment Share on other sites More sharing options...
Mike Downs Posted July 19, 2007 Author Share Posted July 19, 2007 Oops, It should be BM 2408-21 and not 2403 9 Going to have to get a new pair of glasses! Cheers john Quote Link to comment Share on other sites More sharing options...
Mike Downs Posted July 20, 2007 Author Share Posted July 20, 2007 Thanks Jetsome.....I tried a 6x4E the smallest I had just before the rains last night and the problem is the same...regarding your slipping clutch theory...wont the load come off the prop as it goes faster up till its optimum speed? Quote Link to comment Share on other sites More sharing options...
Allan Jordan Posted July 20, 2007 Share Posted July 20, 2007 Hi John, I'm with Jetsome on this one! I would check all of my soldered joints to make sure that I haven't made what is known as a dry joint. You've got to start somewhere haven't you. All the best with your problem.Allan J...TTFN Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted July 20, 2007 Share Posted July 20, 2007 Check the circlip that holds the motor shaft inside the magnets.If this is sitting a long way proud of the back of the motor, you may find that the thrust pulls the magnets sufficiently far forward to reduce the power, or muck up the motor connections.Is the motor a pusher or tractor?I use this combo with 8 nicad cells in sheet-winged speed 400 type models and it works well, and gives these models a good turn of speed.Jetsome's point about being in top gear is also spot on, and with "only" 2s lipos, you may not be spinning the prop fast enough for it to "bite".AlistairTPS - If you've bent the motor shaft in the past, even if you've bent it back, the motor will not work as well as it should (don't ask me.....). New ones cost peanuts and are easy to install;http://www.bphobbies.com/pdf/bp/BPMotorDisassembly.pdf Quote Link to comment Share on other sites More sharing options...
Alan Scarlett Posted January 27, 2011 Share Posted January 27, 2011 How do you woak out the motors for 2 and 4 engines set up. Is it still a 100w per lb Quote Link to comment Share on other sites More sharing options...
