Lee Bentley Posted December 26, 2009 Share Posted December 26, 2009 HELP, I have a Walkera 60 heli that hasn’t flown for over a year now since the second motor failed in flight, anyway, I have decided to resurrect this so have done a couple of mods ie upgraded to brushless and ripped out the supplied useless radio stuff and fitted a Futaba fasst rx . Transmitter is a 6EX. This is where my problems started, following the recommended settings according to the Futaba instructions, no matter what I do I can’t get the elevator servo to mix properly with pitch. Ailerons will work independently as does the elevator, but apply pitch the ailerons go up OK but the elevator servo moves down. Reversing the elevator servo is not an option as this then will not work properly as an elevator ie. Reversed! Has anyone here fitted a Futaba radio to a Walkera 60. I need to get this working as I’ve ordered a TREX 450se and the servo layout I believe is the same. Have a happy new year Lee (sunny France) Edited By Lee Bentley on 26/12/2009 10:33:27 Quote Link to comment Share on other sites More sharing options...
Robert Bromwich Posted December 26, 2009 Share Posted December 26, 2009 have you tried reversing the alireon servos then reversing the pitch on the Tx also have you read this heli setup as i think your having the same problem this guy had rob Edited By Robert Bromwich on 26/12/2009 10:53:41 Quote Link to comment Share on other sites More sharing options...
Lee Bentley Posted December 26, 2009 Author Share Posted December 26, 2009 Ailron and pitch are OK, its the elevator servo thats not not playing properly, works OK as elevator but works in opposite direction when pitch applied. I'll just have a look at the other thread, musta missed it. Quote Link to comment Share on other sites More sharing options...
Lee Bentley Posted December 26, 2009 Author Share Posted December 26, 2009 Problem resolved, I had to fiddle with Reverse and Swash settings to get the right combination, so if any one else comes up with same query, here are the settings that work for me and are dependant on what make the servos are, Servo reverse. #1 nor #2 rev #3 rev #4 nor #5 nor #6 rev SWASH set to 3-S CH-A +50% CH-E -50% CH-P +50% Lee Quote Link to comment Share on other sites More sharing options...
