Sir John Posted January 25, 2010 Share Posted January 25, 2010 I need some help with a conversion which I would like to carry out. I have here a Dave Smith Model - Smartmove 40 - with the following details:- Span 143 cm Lenght 148 cm Weight 1900 - 2700 gms Wing loading 19ozs/Sq.f. Power ic. 40 Two stroke 60 Four stroke Can anyone help me with an Elecric Set-up, Motor, ESC, Lipo's, and Prop size. Many thanks in advance, John. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 25, 2010 Share Posted January 25, 2010 5lb+ pattern ship type model, which will require a good power to weight ratio then, at least 100 watts per pound and probably better at 150.This means a powertrain of around 750 Watts. Decent size prop of maybe 13 X 6 or so.Motor therefore low Kv and capable of at least 750 watts - how about this one ?750 watts means current will be too high ( IMO ) on anything less than 5s battery.Current on 5s will be circa 40+ amps, so get a 50A ESC minimum. Edited By Timbo - Administrator on 25/01/2010 13:39:47 Quote Link to comment Share on other sites More sharing options...
Sir John Posted January 25, 2010 Author Share Posted January 25, 2010 Hi Timbo, Many thanks for your help, I will now get in contact with BRC. Sir John. Quote Link to comment Share on other sites More sharing options...
Ed Anderson Posted April 25, 2010 Share Posted April 25, 2010 Did you complete this conversion? How did it go? Happy with the performance? Quote Link to comment Share on other sites More sharing options...
