Posts posted by David Ovenden
Still flying a Hawker Tomtit built from a Veron kit in 1999. Done 300 flights but have replaced the servos and some new bearings in the super reliable Saito 45 fs engine. Its a good 'un.
As per title. Has anyone used Hobby King Tan Green covering film?
Tan Green HK film If so, what colour is it? Beige? Light Kahki? Light grey/ green?
It's hard to tell from the photoand I can't think of many ARTFs that use such a colour and there doesn't seem to be an Oracover equivalent.
Thanks again Martin. Reliability is the key requirement with retracts.
My experience with an ultrasonic cleaner using just water was disappointing. Nothing like Frank's engine experience. Soaking engine in old/stale glow fuel and scrubbing with a toothbrush helps. Cooking the parts in a slow cooker filled with anti-freeze liquid (outside in a well-ventilated garage with door open) got loads of baked on muck off. The engine was really very clean and almost like new afterwards.
Thanks for the info Martin. At least the E-Flite units are available, but not quite the "scale" retract angle.
Another option might be some 80 degrees units from HK but the reviews are pretty mixed on those.
The retracts supplied with this (somewhat long-in-the-tooth) kit are rather flimsy air units. Given the 75 degree retract angle what replacement electric retracts have people used? And/or what other (reasonably priced ) options are available? Has anyone successfully used the supplied BH pneumatic one for more than a few flights?
For sure there are quite a few 90degree retracts out there but there doesn't seem anything much at a reasonable price in 120 size with 75-80 retract angle.
Good show Paul. Wonder what pilot Phil Kraft used back in the day.
Also OS FT-160 Gemini twin final hours of auction.
Final hours on my auction for the Curtiss Condor twin. Got to make room for new projects.
Last chance tonight for my OS FT-160 Gemini twin with new dual needle carb.
It was last year's build and I'm running out of room ! There's a chipmunk, a Sea Fury and a 1/4 scale Tiger Moth waiting to be finished and a Bobcat Twin that I must finish drawing up ready to build over the winter. I need to find the space for them. The Condor was a project that was 3O years in the making. I am very happy I finished it, that all my design modifications worked, and that I successfully sorted the model out. Time to move on.
- 2
The plane was looking good and the garage smelling of dope when I dropped by this afternoon!
I have now uploaded Paul's video to YouTube. Condor test flight
It was a bit breezy and take off was brisker than normal!
- 3
Thanks Paul. Was it the wind blowing or me shaking?
Very sorry to see the model in more pieces than it should be. At least they are big pieces! Looks like with some time and patience it can be rebuilt to fly again. Having been in similar situation recently I sympathise. Good luck with the restoration.
2 hours ago, Eric Robson said:
Second maiden flight this week, after a lot of right aileron it flew beautifully after 4 mins 60% left in batteries 4 4s 3600. 3rd flight at 50ft it went into a flat spin considerable damage but repairable. the only thing I changed was the throttle cut switch from D to A but when I went to fly it it was still on D, it checked out on the ground and took off as normal till 50ft. on checking the TX it showed throttle cut on switch A. ?????
Really sorry to hear that Eric. What a shame after after 2 good flights. Glad to hear its repairable though. Good luck with the restoration project.
Thanks Andy. Yes it was a very rewarding afternoon after all the effort of the repairs and modifications.
Well today was the day! I was able to test fly the Condor. It is definitely an improved model. After the flights the Tx trims were all still at "neutral". Take-off was good and a landing was no problem either in spite of a fair breeze a bit off the axis of the runway.
Looks like just one 3700mah Lipo will give 5 minutes of mixed flying which is not unreasonable. One could use a larger capacity lipo but it would need to be located further back in the fuselage to avoid the model being nose-heavy.
It was definitely worth repairing the model and making the modifications which have very much improved the flying characteristics of the model. Losing the gyro and shedding 450g of weight together with tweaking the top wing incidence was a good move it seems!
Thanks to Paul for getting some video of the flight.
- 9
Rigging angles all checked and model weighed and balanced. Amazingly it now balances slightly nose down with only one lipo pack instead of two. So I managed to shed nearly 400g of weight and still have the model balance on the CG.
I removed the servos from the tail and moved them to the nose; removed some plywood mounts; changed the Robart wheels for foam ones; removed the gyro and got rid of some extension leads. And this has allowed me to use one 4s 3700 lipo pack I stead of two.
The good news that most of the weight was lost from the extreme nose and tail of the model so hopefully that will also be beneficial. Will now have to see if the rebuild improves the flight characteristics
- 10
4 hours ago, Kevin Fairgrieve said:
I make my own!
Sometimes use the original as a pattern or oil the part and press on the paper. Cut round the markings.
Gasket paper.Me too! Gasket paper is pretty cheap and easy to cut to shape.
2 hours ago, Don Fry said:
Adrian, you are right. Too much trouble.
For me, other side of the Channel, I’ve had to learn how to make crumpets. Now I would point out, given the charge Mr Warburton makes for six of his, you have to be desperate to try.Well, the small Carrefour supermarket near me (Gard) sells crumpets made in the UK but described on the packet as "crepes anglais".
Not yet. Still working on the Condor repair.
Anyone used HK Tan Green covering
in All Things Model Flying
Hi Paul,
Which is why I'm asking. HK's colour descriptions are really very imaginative, almost fantastic sometimes!
