cyclops2 Posted March 16, 2010 Share Posted March 16, 2010 Can I use a Clark Y with good sport scale flying ? Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted March 16, 2010 Share Posted March 16, 2010 The question doesnt make sense, but I think you mean, if you use Clarke Y, will your plane still be a good sports flying machine. The answer is "yes". The full on aerobatics wont be too hot and inverted will struggle, but for general messing around it'll be fine. If you are making the section yourself it wont be a true Clarke Y, so flatten it a bit more and your sports performance will increase. Remember that our models fly with everything from undercambered to flat plate and then to fully convex symetry...you really cant go wrong! David Quote Link to comment Share on other sites More sharing options...
cyclops2 Posted March 16, 2010 Author Share Posted March 16, 2010 Thanks David. Rich Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted March 16, 2010 Share Posted March 16, 2010 cyclops2You say sports scale flying?The Clark Y is a good standard aerofoil and with a largely flat underside it is easy to construct accurately on a building board, however it is little used in full size aircraft (except for propellers) so it is going to depend on how "scale" you want it to look. Now if you built a scale Ryan NYP that Charles Lindberg flew across the Atlantic that actually used a Clark Y wing section. Quote Link to comment Share on other sites More sharing options...
cyclops2 Posted March 17, 2010 Author Share Posted March 17, 2010 Here is a early photo of it. I have started to finally finish the plane. 6 sq ft of WA. Complete RTF weight should be at 2 lbs. 4 GWS 40 mm EDFs. Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted March 20, 2010 Share Posted March 20, 2010 Hi cyclops all ai Can see is the skeletons of the 48" hydroboats things. David Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 20, 2010 Share Posted March 20, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
