Jon Peek Posted March 29, 2010 Share Posted March 29, 2010 Can anyone help please. I have an esc without set up instructions for a 60A R C Smart Esc. I have trawled the internet to no avail. It says 60A4-14NC BEC Thanks in anticipation. Jon. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 29, 2010 Share Posted March 29, 2010 What exactly do you want to do with it. Quote Link to comment Share on other sites More sharing options...
Jon Peek Posted March 29, 2010 Author Share Posted March 29, 2010 Hi, i want to use it in a Multiplex Gemini Bip. The set up is as recommended by the 4 Max site .Cant remember off hand what size elec motor but this was recommended size esc.and set up Cheers Quote Link to comment Share on other sites More sharing options...
Pete B Posted March 29, 2010 Share Posted March 29, 2010 If this is the ESC, it is an OPTO type which means you'll either have to connect a UBEC to it or use a separate battery pack to power the Rx and servos. It looks very much like the SP ESC's sold by Giantcod. You'll find some programming instructions on that site which may help. Pete Just checked GC to find this SP 60A ESC and the spec is worded identically to that on the RC Smart site. Manuals for all the products are found on the GC forumEdited By Pete B on 29/03/2010 19:28:36 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 29, 2010 Share Posted March 29, 2010 Not much to go on there JonHave you tried running it on default out of box settings ? Usually, all thats required is to teach the throttle throws and away you go.1) Remove prop2) Switch on Tx and put throttle to HIGH3) Connect ESC to battery...wait for beeps4) Move throttle stick to LOW....wait for more beeps.5) Disconnect ESC, and switch off Tx. Now, all future switch on procedures should be as per normal, with throttle set to low. Quote Link to comment Share on other sites More sharing options...
Jon Peek Posted March 29, 2010 Author Share Posted March 29, 2010 Thanks for the help and advice gents. I'll have a look at the giant cod forum. Cheers. Quote Link to comment Share on other sites More sharing options...
Pete B Posted March 29, 2010 Share Posted March 29, 2010 Just noticed that GC do both BEC and OPTO versions of the 60A, Jon - yours could be either! Pete Quote Link to comment Share on other sites More sharing options...
Jon Peek Posted March 29, 2010 Author Share Posted March 29, 2010 Hi Pete, havn't tried the instructions on the GC forum yet will do that tomo,but does look the same as the one I have I'm well pleased thanks, really appreciate your help, thanks again, Jon. Quote Link to comment Share on other sites More sharing options...
