Hamish Posted March 29, 2010 Share Posted March 29, 2010 Went to my LMS to pick up some triangular section. Had the wood in my hand when I was asked to look at it and was it what I wanted. It was cut at 3 angles of 60 degrees and not 2 at 45 and one at 90. The problems they are having to explain this to there supplier. Having been sharpening my modeling skills I bought sheet balsa with the thought that I would just set a blade at 45 degrees and strip it down. Naw, not so easy. Grateful for any tips from the experienced balsa bashers on how to do it. Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted March 29, 2010 Share Posted March 29, 2010 Hi Hamish, lots of ways to do this have a look at this earlier threadEdited By Timbo - Administrator on 29/03/2010 23:37:22 Quote Link to comment Share on other sites More sharing options...
Hamish Posted March 29, 2010 Author Share Posted March 29, 2010 Thanks rActive, You must have a better search engine than mine. For all the difference in weight I will just cut a square section. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 29, 2010 Share Posted March 29, 2010 Hamish the new search facility on the forum works well these days Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted March 30, 2010 Share Posted March 30, 2010 My pleasure, I found it because I remembered posting to it square is easier to deal with unless you have lots of formers that would need a square notch taking out. Good luck for the build. Quote Link to comment Share on other sites More sharing options...
Hamish Posted March 30, 2010 Author Share Posted March 30, 2010 Posted by Timbo - Administrator on 29/03/2010 23:37:51:Hamish the new search facility on the forum works well these days Perhaps, but a simple "Cutting balsa" brought nothing relating to triangular stock Edited By Hamish McNab on 30/03/2010 09:09:12 Quote Link to comment Share on other sites More sharing options...
